Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > Which speakers for my doors?
Author Thread: Which speakers for my doors?
My doors of my truck have factory tweeters in top and 5x7 in bottom. I want to replace the factory system, so should I get a component set or can i buy 2-way 5x7s and separate tweeters?
Username: Glasswolf
Post Number: 1387
go with 5.25" separates.
tweeters in factory dash locale, mids in the 5x7 holes
Username: Wk1775
The tweeters are in the doors. No dash speakers. Thanks. I want to get the infinity kappas. Should I get a separate amp or will the alpine V-drive amp from the head unit work fine?
Username: Glasswolf
Post Number: 1399
the alpine should power them just fine.
if you're not happy with that, then look at an amplifier afterward.
Username: Tbone
Post Number: 11
also, you can reduce cancellation by back waves if you mount the 5.25's on a fabricated plate, then mount them in the 5x7 holes.
Username: Glasswolf
Post Number: 1416
you won't have an issue with standing wave reflection in a door panel, since the inside of the door isn't a strictly parallel surface to the mounting panel of the speakers. You could use a dynamat speaker baffle however, to reduce resonance and give better midbass response.
Username: Tbone
Post Number: 12
Agreed, I baffled my 6 1/2 seperates in my door and they sounded a lot cleaner, and provide protection from misc. dust.
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through April 16, 2004 > Which speakers for my doors? [ « Previous ] [ Next » ]
