Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > Kicker Setup HELP
Author Thread: Kicker Setup HELP
Username: Xotas80
Im kindof a newbe at this but i have a Kicker kx200.2 2 channel amp and ive bridged it and its all set up to my panasonic head unit and my
Kicker CVR 12. I have bugger all of an idea what crossover i should use on the amp and on the head unit. I dont know how they work nor do i know how to set up the bass boost properly.
Most of the time if i try to turn it up it just does that circuit protection thing and turn off.
Need help somthing shocking.
Username: James1115
Wilton, Ct
Post Number: 2207
you are going to want to use the LPF which is low pass filter, run it at 80htz. I wouldnt really play around with the bass boost all that much maybe turn it up a hair but not to much that is most likely causing your amp to clip and go into protection mode.
Username: Xotas80
ok cool, mm im still not sure what to set the head unit at? Its got low pass frequency (crossover) stuff as well. Should i set that to the same as the crossover on the amp?
Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > Kicker Setup HELP [ « Previous ] [ Next » ]
