Thread: 4 channel amp to one speaker? |
Unregistered guest |
| Posted on Friday, April 08, 2005 - 05:18 pm: |
Hi, i was wondering if you can wire up a 4 channel amp to one sub, the amp is a Crossfire CFA-404S 4x100 rms and the sub is a eclipse 8810 dvc. |
Gold Member Username: Carguy
Post Number: 2271 Registered: Nov-04
| Posted on Friday, April 08, 2005 - 05:27 pm: |
That's a sure way of blowing your amp and the sub. |
| Posted on Friday, April 08, 2005 - 05:35 pm: |
So i can only bridge using 2 channels on the amp?. |
Post Number: 2272 Registered: Nov-04
| Posted on Friday, April 08, 2005 - 05:52 pm: |
4 channel amps will bridge into 2 channel amp, 2 channel will bridge to mono. If you get confused, think of 4 channel as 2 2 channel amps. |
| Posted on Friday, April 08, 2005 - 06:02 pm: |
cheers mate thought as much. thanks for the info. |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 206 Registered: Mar-05
| Posted on Saturday, April 09, 2005 - 06:32 am: |
It would be a nice light show |
