Thread: Symbilink |
Silver Member Username: Joebruce
KY
U.S.A.
Post Number: 209 Registered: May-04
| Posted on Friday, April 08, 2005 - 05:00 am: |
I have a zapco c2k 2.0x and it doesnt take regular rcas,I was wondering instead of spending a couple hundred on the symbilink if i could just get the din to rca cable from zapco and use it like regular rcas. And does anyone know if it comes in any shorter length than 18ft. cuz i only need like 10 ft. |
Silver Member Username: Tragedy
San Jose,
CA
Post Number: 200 Registered: Feb-05
| Posted on Friday, April 08, 2005 - 01:49 pm: |
if you have a 2.0x you amp should of came with a symbilink converter. One end will come with (L) and (R) rca inputs and the other will be Din out. From there you run the balanced line in to the amp. The din cables come in 6, 12, 18ft. |
KY
U.S.A.
Post Number: 210 Registered: May-04
| Posted on Friday, April 08, 2005 - 06:09 pm: |
Oh well it was used i got it off ebay and it didnt come with anything like that,so can i just buy the din to rca cable and use that? |
San Jose,
CA
Post Number: 201 Registered: Feb-05
| Posted on Friday, April 08, 2005 - 06:35 pm: |
talk to bob at zapco hes always been helpful with me heres his email bob@zapco.com just tell him your symbilink for your 2.0x got broken or lost and what should you use and how much. |
