Thread: Orion HCCA 225 or PPI art A600.2 |
New member Username: Sldonmtns
Ca
Post Number: 1 Registered: Apr-05
| Posted on Friday, April 08, 2005 - 12:07 am: |
I just got a pair of CDT EF-61cf components (4 ohm, 150w rms), and I need to power them. I am looking for mainly sound quality, not loudness. I've done a search and read that the orion 225, can power components just fine, but I am still worried because i've read the ef-61cf's are really power hungry. I want save as much money as possible, so i would rather go with the orion. Thanks for any help. |
Gold Member Username: Carguy
Post Number: 2248 Registered: Nov-04
| Posted on Friday, April 08, 2005 - 12:58 am: |
If you want a bit higher power, then PPI 600.2 will do. However, HCCA 225 is .5ohms stable in stereo mode and is 400w rms minimum. They're both great amps and give amazing sound quality.
Ca
Post Number: 2 Registered: Apr-05
| Posted on Friday, April 08, 2005 - 01:05 am: |
Is there a way to run just one set of components at 1ohm on the hcca 225? |
Post Number: 2251 Registered: Nov-04
| Posted on Friday, April 08, 2005 - 01:11 am: |
The only way you can do that is to get 2 pairs of 2ohms components and hook them up to HCCA 225. Is HCCA 225 a G4 model or a digital reference? G4 comes with crossover controls as well as bass enhancements. |
Ca
Post Number: 3 Registered: Apr-05
| Posted on Friday, April 08, 2005 - 01:20 am: |
i was looking at either the g4 or the digital references w/ external crosssovers, but because I'll only be running one pair of 4 ohm components, I'll probably go with the a600 instead. |
Ca
Post Number: 4 Registered: Apr-05
Gold Member Username: James1115
Wilton,
Ct
Post Number: 2175 Registered: Dec-04
| Posted on Friday, April 08, 2005 - 01:21 am: |
for that set-up I would deff go PPI a600 but that isnt saying anything bad against the Orion I own a a600.2 and an HCCA 250g4 so I love them both. |
skyliner17 Unregistered guest |
| Posted on Friday, April 08, 2005 - 03:01 am: |
i would go with the PPI a600 too myself since your just powering components. orion amps are too big and take up too much space. |
