Thread: Isaac, I got a question..... |
Silver Member Username: Kojak28
Augusta,
GA
Post Number: 129 Registered: Feb-05
| Posted on Thursday, April 07, 2005 - 10:23 pm: |
If I run Orion 6.2s in the front (3ohms) and Concept 5.25s in the rear (4ohms), what would the ohm load be to a 2ch amp if run parallel? |
Gold Member Username: Carguy
Post Number: 2243 Registered: Nov-04
| Posted on Thursday, April 07, 2005 - 10:32 pm: |
Hey Kojak28, if you wire 3ohms and 4ohms in parallel, you will get around 1.71ohms total. |
Augusta,
GA
Post Number: 130 Registered: Feb-05
| Posted on Thursday, April 07, 2005 - 10:33 pm: |
So a 2ohm stable PPI amp wouldn't cut it, huh? |
Post Number: 2245 Registered: Nov-04
| Posted on Thursday, April 07, 2005 - 10:38 pm: |
It will be very close. Only one way to find out, get a DMM and measure after they're wired. Not all speakers are created equal. Some of the 3ohms are 3.5ohms and some of the 4ohms are 4.5. So if you're lucky, the resistance might be 2ohms.
Augusta,
GA
Post Number: 132 Registered: Feb-05
| Posted on Thursday, April 07, 2005 - 10:43 pm: |
Good point....BUT after I get everything wired up and I spend $1k buying my equipment, and it doesn't work, I'll prolly have to sell and start over. Sux. |
Post Number: 2247 Registered: Nov-04
| Posted on Thursday, April 07, 2005 - 10:47 pm: |
Anything electronic CAN be made to work, so don't worry too much. |
