Thread: Which amp should I buy? |
New member Username: Mike318ti
Post Number: 1 Registered: Apr-05
| Posted on Thursday, April 07, 2005 - 09:47 pm: |
Hey Guys! I just recently purcahsed: Two Audiobahn AW102T Natural Excursion 10" Subwoofers Specs- Impendance: 4 Ohms Voice Coil: Single Sensitivity: 92.3dB 450 Watts RMS I have a 1995 BMW 318ti and i'm looking to build a box similar to this on each side on the hatch,
What kind of amplifier would you guys recommend I buy for this setup. PS: I'm not looking to spend more than $300 on the amp. Preferably something in the $100-250 range. Thanks, -Mike |
Gold Member Username: Carguy
Post Number: 2237 Registered: Nov-04
| Posted on Thursday, April 07, 2005 - 10:06 pm: |
You can try Orion HCCA 250G4, PPI PC/PCX series, MTX and Audiobahn A8000T ($130).
Post Number: 2 Registered: Apr-05
| Posted on Thursday, April 07, 2005 - 10:24 pm: |
Thanks Isaac, Would you happen to know a good reliable website that sells those amps? -Mike |
Post Number: 2244 Registered: Nov-04
| Posted on Thursday, April 07, 2005 - 10:34 pm: |
eBay should have them all. 250G4 and PPI PC/PCX series are time limited items. So if you don't buy now, they might not be available later. |
