Thread: What kind of amp do i need for my subwoofers? |
New member Username: Sixth
Post Number: 9 Registered: Nov-04
| Posted on Thursday, April 07, 2005 - 01:43 am: |
2 Audiofonics 12 " Subwoofer 1200watt Dual 4 ohm Voice Coil Aluminum former Aluminum Die Cast Basket Double Stack Magnet Foam Edge Surround Push Type Terminals Voice Coil Ventilation High Excursion Low Frequency Response Chrome Plated T-Yoke / Top plate 600 Watts Continuous Power Rating 1200 Watts Max peak power Recomended Box Volume 1 - 1.25 cu ft. sealed , or usa a standard 12" bandpass box.
Gold Member Username: James1115
Wilton,
Ct
Post Number: 2163 Registered: Dec-04
| Posted on Thursday, April 07, 2005 - 02:16 am: |
either something 1200 watts at 4ohms or 1200 watts at 1ohm. |
Bronze Member Username: Sixth
Post Number: 12 Registered: Nov-04
| Posted on Thursday, April 07, 2005 - 02:44 am: |
ok thanx |
Post Number: 14 Registered: Nov-04
| Posted on Thursday, April 07, 2005 - 03:04 am: |
can i do 1000 watts 2 ch @ 1 ohm or 700 watts 2 ch @ 2 ohm is that sumthing good? |
