Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Where do i find a 300amp alternator?
Author Thread: Where do i find a 300amp alternator?
Username: Invictuz
Seattle, Wa
Usa
Post Number: 40
I contacted alterstart.com (i think that was the site suggested) and they only had a 205amp.
Alternatively, how difficult is it to rebuild my current 120amp to 300amp?
Username: Wireaudio
Wood Dale, ILLINOIS
That's hard to find man good luck with that one!
Username: Southernrebel
Monroe, Louisiana
Post Number: 518
I'm not sure if an OEM case alt can be rebuilt to a 300A. You can buy a huge alt though. Try ohio generators.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=14932%26item%3D5758208792 %26&ssPageName=WD1V
TRY THIS LINK
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Where do i find a 300amp alternator? [ « Previous ] [ Next » ]
