Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Experience with used amps?
Author Thread: Experience with used amps?
Username: Goon
Post Number: 78
Whats everyone's experience with buying used amps, especialy from ebay? I have some ppi art series amps that are in my price range, but concerned since they are not under warranty. what are your expreiences...good idea, or bad?
goon
skyliner17
i've had very good experience with used, new, etc amps from ebay. just buy from a seller with a lot of good feedback.
Username: Sixth
Post Number: 10
kinda risky but its aiite
Username: James1115
Wilton, Ct
Post Number: 2164
yup skyliner is right I have bought many used amps off of Ebay and been fine you have to check their feedback rating and look into their feedback to see what other buyers have said about them. Typically anyone with 97% or better is usually pretty good.
94red5-oh
I have purchased two PPI amps off of eBay. One, PCX 1250 I got refurbished about a year ago still works perfectly. The other is a PCX 250 that I got brand new, and also works perfectly. Like James said, try to look for sellers with high percentage of positive feedback.
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Experience with used amps? [ « Previous ] [ Next » ]
