Thread: What amp should i Buy |
New member Username: Plhsc6907
Post Number: 2 Registered: Apr-05
| Posted on Wednesday, April 06, 2005 - 05:15 pm: |
I have a 2 Sony Xplod subwoofers with 350 Watts RMS Power, 1200 Watts Peak Power. What brand amp should i buy. I need to know what type of Channel to buy(mono, 2, 4) also what watt range should the amp be at. |
Gold Member Username: Carguy
Post Number: 2221 Registered: Nov-04
| Posted on Wednesday, April 06, 2005 - 05:29 pm: |
In the future, stay away from Sony/Pyramid products. Look for PPI PC/PCX series mono or 2 channel amps around 500w - 600w rms. I doubt Sony will handle 350w rms. They always over rate everything. If you have low budget, then look at MTX.
Silver Member Username: Importrapist
Savannah,
GA
U.S.A
Post Number: 128 Registered: Mar-05
| Posted on Wednesday, April 06, 2005 - 05:47 pm: |
i 2nd isaac.....do what he says Pat |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 157 Registered: Mar-05
| Posted on Thursday, April 07, 2005 - 07:11 am: |
I would sell the Sony's to some unsuspection kid and then try to get some better equipment. |
