Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > A/d/s PH 15 amp question
Author Thread: A/d/s PH 15 amp question
Username: Stanfrog
I'm thinking of using an older a/d/s ph15 to power a couple 10" JLs and either mbQuart, dynaudio or focal component set up front. will the ph15 be enough. i don't know which set to use yet. if you can recommend either of these three i'd appreciate your advice also.
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > A/d/s PH 15 amp question [ « Previous ] [ Next » ]
