Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Precision Power 2150AM amp help!
Author Thread: Precision Power 2150AM amp help!
Username: Bridgelounge
I own a PPI-2150AM amplifer rated at 2X150W.
The speaker output terminals are in molex (adapter) style. Any suggestions on where I could get an adapter and also, does anyone know the arrangement (Remote, R+, R-, L+, L-). The other side of the amplifier has B+ and ground wires.
The 5 metal adpater pins are visible. Maybe I could solder the terminals. I just dont know which is the remote 12V amp turn on. (LOL very important!)
For reference purposes, looking at side amp panel, left to right would be helpful. Thanks! Manny
Username: Carguy
Post Number: 2213
Try this for a test. L-, L+, REM, R+, R-. I have 2 different PPI models and they seem to have the same setup.
Thanks, I'll give that a shot. So, just to clarify, you're stating the remote terminal is in the middle? speaker ground terminals on the outermost ends? I appreciate the quick reply! Manny
Username: Carguy
Post Number: 2217
Yes, that is how most PPI amps are set up.
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Precision Power 2150AM amp help! [ « Previous ] [ Next » ]
