Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Is a performance teknique amo good fo...
Author Thread: Is a performance teknique amo good for my 12' audiofonics?
Username: Sixth
Audiofonics 12 " Subwoofer 1200watt
Dual 4 ohm Voice Coil
Aluminum former
Aluminum Die Cast Basket
Double Stack Magnet
Foam Edge Surround
Push Type Terminals
Voice Coil Ventilation
High Excursion
Low Frequency Response
Chrome Plated T-Yoke / Top plate
600 Watts Continuous Power Rating
1200 Watts Max peak power
Recomended Box Volume 1 - 1.25 cu ft. sealed , or usa a standard 12" bandpass box.
performance teknique amp 2000watt
Features:
2 Channel Bridgeable Power Amplifier
2000W MAX @ 2 ohm
Power Output
350W x 2Ch @ 2 ohm
250W x 2ch @ 4 ohm
700W x 1Ch Bridged
23dB/OCT Crossover Slope
Variable Subsonic Filter (10Hz-100Hz)
Variable Low Pass Filter (30Hz-500Hz)
Variable High Pass Filter (50Hz-1KHz)
Variable 18dB Bass Boost
High & Low Level Input Through RCA
Double Sided PCB
Dual Protection (Thermal & Short Circuit)
RCA Line Out
Power & Diagnostic Led Indicator
2 Ohm Stable
Soft Delayed Power on
Tri Mode Capability
Regular price: $370.00
Username: Sixth
http://shop.store.yahoo.com/csexpo/icpete2chbrp2.html
sumone please go here to see if this is another good amp for my subs thanx.
Username: Bnd_rulez
Phoenix, AZ
Post Number: 124
A JL Audio 500/1 would be a better amp for your sub.
Username: Sixth
Post Number: 7
i got two subs, the jl audio amp is 1000 watts max?
Username: Sixth
Post Number: 8
i need at least 2400 watts to push the subs
Username: Bnd_rulez
Phoenix, AZ
Post Number: 158
You don't need 2400 watts when the subs are only rated at 600 watts RMS. I have never heard of Audiophonics so I don't know if that is even a trus number or inflated. A suitable cheap amp for you would be a Hifonics BX1000D.
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Is a performance teknique amo good fo... [ « Previous ] [ Next » ]
