Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Multichannel amp help
Author Thread: Multichannel amp help
i really dont know that much about car audio, so i need some help.
i have 2 600watt 10 inch alpine type e subsand i want to put a 400 watt 12 inch pioneer sub with it, can i do that?
if i can what multichannel amp should i get a cheap okay one.
thanks
Username: Suleman36
Post Number: 451
Stop asking dumb questions as4hole. No one whould recommend that!!! punk
Username: Fishy
Tamarac Ft.Laud, FL
Post Number: 861
Thats absolutely NOT a dumb question MO.
You could do that Anon, but I'm not sure you get the impedance to match well with your amp plus it might not sound so hot. Its generally not a good idea from an SQ standpoint to mix and match drivers running at the same frequencies.
-Fishy
thanks fishy
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Multichannel amp help [ « Previous ] [ Next » ]
