Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Quick question
Author Thread: Quick question
derekk
I attempted to wire up my Alpine mrd-m301 today and connected the positive to a 12v car battery and ground etc... I was expecting to get at least the 12v displayed on the front, Is this because the Remote lead was not connected, and if so how can i replicate the remote signal??
Thanks guys
Username: Tragedy
San Jose, CA
Post Number: 194
maybe this makes sense to someone but what is exactly your problem? wasnt clear.. and what are you asking if you can do?
Username: Addicted2bass
Miami, FLORIDA
Post Number: 472
What did you see on the display
derekk
i just bought it second hand and wondered if it worked, its got a display on the front which displays the voltage when on, so i need to know if its broken or just because the remote lead isnt plugged in?charz
derekk
Anyone :-(
derekk
Anyone :-(
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Quick question [ « Previous ] [ Next » ]
