Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Zapco for RE SE?
Author Thread: Zapco for RE SE?
Username: Scab12886
Post Number: 127
is the zapco ref500 a good amp to run one 12 inch RE SE? or are there better options? the sub is dual 4ohm. thanks in advance.
Username: Tragedy
San Jose, CA
Post Number: 195
REF 500.1 (500rms @ 2ohm) would be a perfect amp for the SE rated at 600rms.
You probably cant get any better than that unless you went with a moded (bridged 2ohm stable mono) 3.0x from the Zapco C2K that puts out 600rms but that would be an overkill.
Username: Scab12886
Post Number: 128
alright. thanks a lot tragedy.
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Zapco for RE SE? [ « Previous ] [ Next » ]
