Thread: I have an audiobahn a8002t amp what subs would sound good? |
New member Username: Jameslnr
Post Number: 1 Registered: Apr-05
| Posted on Monday, April 04, 2005 - 07:27 pm: |
Gold Member Username: Carguy
Post Number: 2184 Registered: Nov-04
| Posted on Tuesday, April 05, 2005 - 04:59 pm: |
It'll depend on what type of sound you're looking for. |
Bronze Member Username: Johnnysanz3
Post Number: 35 Registered: Mar-05
| Posted on Tuesday, April 05, 2005 - 09:42 pm: |
isaac, i want a sub that will set off car alarms when i drive by them...with my a8000t amp, what would be the best sub for that?, i cant go bigger than 15", it wont fit |
Post Number: 2190 Registered: Nov-04
| Posted on Tuesday, April 05, 2005 - 10:38 pm: |
Sounds like you need a sub with high sensitivity. Try JL or RE X.X.X. series. If you have the money, then those 2 should give you the result. Make sure the box is made to the manufacturer's spec. |
