Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > What type of batterey
Author Thread: What type of batterey
Username: Perrydog
Flint, Michigan
Post Number: 94
what type of batt. should i put in my car for runnin my syster(under the hood batt.)
Username: Theelfkeeper
Stockbridge, GA
Post Number: 198
go with an Optima Yellow Top
Username: Velk4425
Post Number: 10
Yes, Optima is the way to go.
Username: Perrydog
Flint, Michigan
Post Number: 95
shoudl i go with a deep cycle?http://www.autozone.com/servlet/UiBroker?UseCase=C003&UserAction=performSearch&P arameters=Auto+Store|~NON+APPLICATION|~Batteries on this page wich one is the best there is a lot of yellow top whats the difference?
Username: Carguy
Post Number: 2164
The link doesn't work for me. It gives me an error.
Walmart sells Yellow top Optima battery. Deep cycles are good for environments where you will be listening to the stereo with engine off.
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > What type of batterey [ « Previous ] [ Next » ]
