Thread: Can i bridge a 2 channel amp to 1 sub woofer? |
| Posted on Sunday, April 03, 2005 - 07:49 pm: |
my sub-woofer has dual voice coil |
Silver Member Username: Jeremyc
OK in less t...
South Korea
Post Number: 623 Registered: Jun-04
| Posted on Sunday, April 03, 2005 - 09:58 pm: |
what type of amp? Is it one ohm or two ohm stable? How many watts rms? What type of speaker? Are the coils 2 or 4 ohm? What is the rms rating of the speaker? |
andre04 Unregistered guest |
| Posted on Monday, April 04, 2005 - 10:47 pm: |
I have just installed a Sony Xploid amp to a single sub. The sound, at this point is just ok. I cannot adjust the gain to tune the quality. I need to know why the amp cuts out when I turn on the car. I can use the amp, at a limited volume, when I turn on only the accessories. Please help!! |
Bronze Member Username: Spittin2rock
Post Number: 99 Registered: Mar-04
| Posted on Tuesday, April 05, 2005 - 12:04 am: |
sure you can if its bridgeable in which I don't think I've ever seen an 2 channel amp that wasn't bridgeable. you would have to find out which channel uses it negative terminal and which channel uses it positive terminal to the bridge channel. If your amp supports a 2 ohm load to the mono channel then wire your Voice coils in parallel then hook it to the mono channel. If it doesn't then just hook each voice coil to a channel. |
Post Number: 100 Registered: Mar-04
Nick_sq Unregistered guest |
| Posted on Tuesday, April 05, 2005 - 12:16 am: |
Your sub is likely Dual 4 ohm voice coils, so in that case no, you can't (unless you want to bridge to 8 ohm with a pretty considerable loss of power) If you subs happen to be dual 2 ohm or dual 8 ohm, then yes, you can. All this depends aswell on your amplifier...Can it be bridged? Very few 2 channels cant be bridged but some cant so just checking. |
| Posted on Tuesday, April 05, 2005 - 12:36 am: |
