Thread: Bridging question |
New member Username: Nsc
Post Number: 1 Registered: Apr-05
| Posted on Sunday, April 03, 2005 - 06:49 pm: |
I got 2 12" Quantum Audio Compition subs and a quantum 1100 watt amp. I got them hooked up but there not hittin as hard as they should. how could i make them hit to there full capacity? |
Post Number: 2 Registered: Apr-05
| Posted on Sunday, April 03, 2005 - 06:56 pm: |
By the way the amp is only a 1 channel amp |
Silver Member Username: Byrumjr
Post Number: 175 Registered: Jan-05
| Posted on Sunday, April 03, 2005 - 10:26 pm: |
The amps rms at 4 ohms and 2 ohms will help. The subs are they dvc or svc? what ohms and rms watts for the sub. |
Post Number: 4 Registered: Apr-05
| Posted on Monday, April 04, 2005 - 12:46 am: |
Well i know the Max output is 1500 watts a sub but i will check tomarrow |
Bronze Member Username: Spittin2rock
Post Number: 91 Registered: Mar-04
| Posted on Monday, April 04, 2005 - 02:20 pm: |
Quite simple... First you want to know exactly the ohm load your amp is stable at. Second you would want to know what impedence your subs are. Third if the subs are single voice coil or dual voice coil. Then input the following info on this site http://www.rockfordfosgate.com/rftech/wiringwizard.asp and it will tell you the different wiring configurations and the ohm load your subs will present to the amp.
Post Number: 5 Registered: Apr-05
| Posted on Tuesday, April 05, 2005 - 07:31 pm: |
i found the problem i had it bridged right i just had 12 gauge wire when i needed 8 thanks for the help. if yall want to see my system this is the site http://www.quantumaudio.net |
Silver Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 102 Registered: Mar-05
| Posted on Wednesday, April 06, 2005 - 01:42 am: |
When you bridge an amp does it drop/gain ohms, or does it stay the same? I have a DVC 2 ohm sub and I am bridgeing my amp for it. So if the amp doesn't gain/drop ohms, I would want to wire my sub in series? |
Phoenix,
AZ
Post Number: 142 Registered: Mar-05
| Posted on Wednesday, April 06, 2005 - 06:23 am: |
Bump. |
Phoenix,
AZ
Post Number: 155 Registered: Mar-05
| Posted on Thursday, April 07, 2005 - 06:57 am: |
ANyone? |
