Thread: How to hook up to amps to one sub |
Bronze Member Username: Bootykang
Post Number: 21 Registered: Jan-05
| Posted on Sunday, April 03, 2005 - 12:05 pm: |
Hey how can i hook up my two amps to my sub |
Silver Member Username: Byrumjr
Post Number: 171 Registered: Jan-05
| Posted on Sunday, April 03, 2005 - 12:54 pm: |
Hooking up two amps on one sub is a bad ideal. If the sub is a dual voice coil, then you can hook each amp to each voice coil of the sub. This is bad for the sub because the amps will not put out the same watts. Dual voice coils have a RMS values, most of the time each voice coil gets half of the rms. So most likely it would over power the voice coil. |
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 191 Registered: Feb-05
| Posted on Sunday, April 03, 2005 - 04:41 pm: |
it really depends on the amp i think, if they are good and regulated, then i don't see any problem (JL for example). but if they are cheap (sony for example) then who knows what they will do |
