Thread: 4 gauge amp kit fuse |
Bronze Member Username: Point78
El cajon,
Ca
Post Number: 32 Registered: Feb-05
| Posted on Sunday, April 03, 2005 - 01:19 am: |
i just bought a 4 gauge full wiring kit and it only came with a 60amp fuse from the battery. i am running a 1000 watt amp should i get a bigger fuse or is the 60amp fine? |
Silver Member Username: Byrumjr
Post Number: 168 Registered: Jan-05
| Posted on Sunday, April 03, 2005 - 01:52 am: |
4 gauge is recommended maximum fuse size of 125 amp. 60 amp fuse will work unless your amp draws more than 60 amps. You say your running a 1000 watt amp is this rms or max? What size fuse does your amp have? |
El cajon,
Ca
Post Number: 34 Registered: Feb-05
| Posted on Sunday, April 03, 2005 - 01:28 pm: |
my amp has 2 60amp fuses
| Posted on Sunday, April 03, 2005 - 03:00 pm: |
its best to find a 120amp fuse for your wiring kit |
| Posted on Sunday, April 03, 2005 - 03:12 pm: |
ur gonna have to get a new inline fuse holder. Get an ANL fuse holder and they have 100 150 and 200 amp fuses. |
El cajon,
Ca
Post Number: 36 Registered: Feb-05
| Posted on Sunday, April 03, 2005 - 08:15 pm: |
thanx |
