Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Are crossovers needed?
Author Thread: Are crossovers needed?
Username: Msully701
Stratford, Connecticut
US
are they needed in every system? or is it just if you want them.
Username: Glasswolf
NorthWest, Michigan
Post Number: 7535
totally depends on the system.
component separates require crossovers that come with the speakers.
subs require a crossover, but most sub amps today have a LPF built in already.
I usually suggest using a HPF for components just to eliminate low frequencies that cause the speakers to bottom out.
it's totally up to you though.
Username: Scubasteve
Annapolis, MD
Post Number: 36
You guys seem to prefer exterior crossovers over those built into amps. If its a good amp, such as a JL, how much better will it be to use an external amp instead?
Username: Illuminator
Post Number: 678
Shockingly better.
Username: Racer501
ND
Post Number: 244
so if your amp has a built in cross over for the low frequencies then you would only need a 2-way crossover for your mid's and highs right?
Username: Southern_bass
Paris, Tennessee
U.S.
Post Number: 376
yup
Username: Racer501
ND
Post Number: 248
now to go see if my amp has a built in cross over ....
Username: Racer501
ND
Post Number: 249
Active Crossover: 12dB/Octave, variable 50Hz-200Hz, selectable high pass, low pass, or all pass;KX100.2 hig or low fixed @ 80Hz would that work for a low pass cross over?
Username: Racer501
ND
Post Number: 256
Home > Message Board > Car Audio > EQs and Crossovers > Archive through August 01, 2006 > Are crossovers needed? [ « Previous ] [ Next » ]
