Thread: System help |
New member Username: Msully701
Stratford,
Connecticut
US
Post Number: 1 Registered: Apr-05
| Posted on Saturday, April 02, 2005 - 04:17 pm: |
I am getting rid of my old legacy system I got off ebay it was ok I guess, I want to go better and have about 1200 bucks to drop and plan on useing ebay to get better deals. I was thinking audio bahn everything or kicker. I know how to hook a system up but dont know the technical stuff on amps/subs. I was wondering what ohm's have to do with it. like to I have to match the ohm's on the sub with the ohm's on the amp? is there any rules of connecting them? I think im going for a stinger 3 farad capacitors with 1 15" Audiobahn immortal awis15p thats quad 2 ohm. I was wondering what kind of amp would work with it. and if the amp I get should it max out the RMS or total wattage? im basically an idiot on that stuff so if anyone could help me I would be greatly appreciative my aim is Msully70 if you want to talk. |
Silver Member Username: Davids2004
Houston,
TX
Post Number: 758 Registered: Jun-04
| Posted on Saturday, April 02, 2005 - 04:38 pm: |
Well the main thing you wanna look at is rms ratting on the amp and sub and match those. What is it that you are trying to establish just insanely bass or good bass and some good sound quality. |
Stratford,
Connecticut
US
Post Number: 2 Registered: Apr-05
| Posted on Saturday, April 02, 2005 - 04:40 pm: |
Im looking for good bass and some good sound quality |
Bronze Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 82 Registered: Mar-05
| Posted on Sunday, April 03, 2005 - 06:45 am: |
You're going to want to stay away from Audiobahn. Especially if you have that much dough to drop. Are you going to get speakers? Do you have a HU? How many amps do you want to use? |
