Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > Two amps on one 4 gauge wire?
Author Thread: Two amps on one 4 gauge wire?
Username: Jseek116
Waterloo, Iowa
I have a 4 gauge wire running to a 350W two cannel amp that powers my one 12"rockford fosgate HE sub. I want to install a 4 channel 680W amp to my door speakers. Is it possible to split the 4 gauge wire so that I only have one power cable. This sounds like a bad idea,but I wanted to ask any ways.
Username: Jwbulger79
Florida
Post Number: 381
yup, that's fine. all you will need is a distribution block. check the "amplifier installation" section of www.sounddomain.com for one. i'm assuming that 680W is max rating. look for a distribution block that has a 4ga input and two 8ga outputs.
how do u put the amps together withour runnign another ac and remote cord back to a new amp then
Home > Message Board > Car Audio > Amplifiers > Archive through April 11, 2005 > Two amps on one 4 gauge wire? [ « Previous ] [ Next » ]
