Thread: What do I get and how? |
Bronze Member Username: Calaway
Austin,
TX
Post Number: 30 Registered: May-04
| Posted on Friday, April 01, 2005 - 08:18 pm: |
I have 2-RFD2208 8 inch dual 4ohm 400RMS subs. I am looking to wire them with a RF 800.2(400w RMSx2 at 2ohms) Will this work? How do I wire?
Silver Member Username: Jwbulger79
Florida
Post Number: 384 Registered: Nov-04
| Posted on Friday, April 01, 2005 - 09:14 pm: |
yes. wire the vc's of each sub in parallel to one channel of the amp per sub. http://www.bcae1.com/spkrmlti.htm |
Austin,
TX
Post Number: 31 Registered: May-04
| Posted on Saturday, April 02, 2005 - 01:36 am: |
J.W. Thanks for the help. On that page you linked, do I follow the diagram right before the water pump examples start? |
Florida
Post Number: 389 Registered: Nov-04
| Posted on Saturday, April 02, 2005 - 10:33 am: |
yup. |
Austin,
TX
Post Number: 32 Registered: May-04
| Posted on Saturday, April 02, 2005 - 08:33 pm: |
Hey J.W. or anyone, sorry to throw another curve. The only other amp I am looking at is a Kicker KX650.4 that is 325RMSx2(bridged) 4 ohms stable. I am unsure how to make a 4 channel amp into 2 channels and then hookem up to my 4ohm DVC subs. Help?? |
Gold Member Username: Taylor17
Kopperl,
Texas
Post Number: 1255 Registered: Jan-05
| Posted on Saturday, April 02, 2005 - 09:20 pm: |
Go with the Rf amp. |
Austin,
TX
Post Number: 33 Registered: May-04
| Posted on Saturday, April 02, 2005 - 10:37 pm: |
Money is kind of an issue.. would there be a problem with the Kicker? |
Florida
Post Number: 392 Registered: Nov-04
| Posted on Sunday, April 03, 2005 - 01:15 am: |
you'd be ok with that kicker amp. just bridge it to two channels. check the manual on what's the exact hookup. pretty sure that amp is bridgable. what's your budget? |
Austin,
TX
Post Number: 34 Registered: May-04
| Posted on Sunday, April 03, 2005 - 04:02 am: |
Thanks, I could get the RF amp just a bit of a stretch money wise. What is the main advantage it has over the Kicker? |
Austin,
TX
Post Number: 35 Registered: May-04
| Posted on Monday, April 04, 2005 - 01:00 am: |
please anyone.. |
Florida
Post Number: 397 Registered: Nov-04
| Posted on Monday, April 04, 2005 - 02:05 am: |
i'm not a big fan of RF's new amps. kicker makes better amps right now. if you're not set on getting something new, i would look for an older orion on eBay. the XTR800.2 would destroy either of those amps. ppi PC class amps are good also. |
Austin,
TX
Post Number: 36 Registered: May-04
| Posted on Monday, April 04, 2005 - 02:52 pm: |
thanks, will go with the Kicker and see what I see.
