Thread: Clipping question.... |
Bronze Member Username: Goon
Post Number: 61 Registered: Feb-05
| Posted on Friday, April 01, 2005 - 06:02 pm: |
While listening to your subs...how will you know if the amp is clipping. I just want to know some signs of clipping for when i get mine all set up. thanks guys. goon |
Gold Member Username: Carguy
Post Number: 2157 Registered: Nov-04
| Posted on Saturday, April 02, 2005 - 10:50 am: |
Trying to find clipping via ears is very hard, especially at high volumes. In a controlled environment, you will have to listen to the same tone over and over till you get used to a clean sound. Then force the amp to clip (this will damage/distroy your sub/amp). Instead of producing clean sound wave, it'll start dropping, giving you "distorted" sound. Best way to see it is via oscilloscope/clip meter. If you are not electronically advanced, then I'd suggest buying high quality amps. They tend to clip much less than Sony/Pyramid/Lanzar/Pyle/Hifonics/Boss etc.
Silver Member Username: Johnnylemoine
LaPlace,
Louisiana
United States
Post Number: 488 Registered: Aug-04
| Posted on Saturday, April 02, 2005 - 04:11 pm: |
how bad do orion amps clip? specifically the old Orion XTR 1000 class d mono block from like '91 or '92. i just got one. |
Post Number: 2159 Registered: Nov-04
| Posted on Saturday, April 02, 2005 - 05:07 pm: |
You purchased one of the good ones. All amps can be made to clip, some almost do it themselves like Pyramid/Sony crap.
Post Number: 62 Registered: Feb-05
| Posted on Saturday, April 02, 2005 - 05:27 pm: |
I got a ppi pcx 1250....i heard they were excellent amps, how do those fair when it comes to clipping? how much do those meters go for generaly? thanks for all the help guys. goon |
Bronze Member Username: Johnnysanz3
Post Number: 22 Registered: Mar-05
| Posted on Saturday, April 02, 2005 - 08:13 pm: |
hey isaac how about the audiobahn a8000t amp, how about that? and also whats a good way to set the input sensitivity on that? u think that amp actually is putting out 800 watts at 2ohms? and also, what do u think causes the sub to be louder or softer at times on the same song? |
nick_sq Unregistered guest |
| Posted on Sunday, April 03, 2005 - 03:10 am: |
That orion amp is bulletproof....if amps were still made as well as the early 90's orions we would be paying about $10,000 for a 1000 watt monoblock. You know there are alot of people who would pay alot of money for an old orion like that. |
LaPlace,
Louisiana
United States
Post Number: 491 Registered: Aug-04
| Posted on Sunday, April 03, 2005 - 04:21 am: |
dude i hear ya on that. im getting that b!tch as soon as i get enuff money. im using my friends right now. IT SLAMS THAT SX 12! |
Post Number: 2160 Registered: Nov-04
| Posted on Sunday, April 03, 2005 - 04:15 pm: |
Johnnysanz3, A8000T is a good amp for the money. You probably won't find one cheaper than that. Set the level control to your HU's preout voltage. Most are 4v, so it should be close to half way on A8000T. I am not sure if you'll get 800w rms of clean power @ 2ohms. Only one way to find out, measure the current flow of the amp. As for sound variation, on same song, check your voltage and current. An amp should deliver same output power when given constant power supply. In a car, that can fluctuate depending on devices used at the same time and rpm speed.
Post Number: 27 Registered: Mar-05
| Posted on Sunday, April 03, 2005 - 04:24 pm: |
I think my head unit pre out voltage is 2v, so is that like 1/4 way?
Post Number: 29 Registered: Mar-05
| Posted on Sunday, April 03, 2005 - 04:29 pm: |
how do i measure the current flow? |
Post Number: 2161 Registered: Nov-04
| Posted on Monday, April 04, 2005 - 10:08 am: |
You don't want to guess what your HU's voltage is. Check your owner's manual. With a DMM, you can measure the current flow of the amp. So for example, let's say at or near 85% volume level, the amp draws 40A. If you take that and multiply by 12v, it'll give you an approximate power the amp is putting out.
Post Number: 32 Registered: Mar-05
| Posted on Monday, April 04, 2005 - 11:16 am: |
ya, i got the voltage from the owners manual, i just had to go back and check in case i read wrong. And just by listening to it it seems anywhere past 1/4 or 3/8 gain it will start to distort/rattle or something...sometimes i cant tell whether its the crappy box or the sub distorting. Now once i set my gain, if i turn stuff up like bass boost on the amp, will that send it in to clippping? Can i adjust that freely? |
Post Number: 2165 Registered: Nov-04
| Posted on Monday, April 04, 2005 - 12:23 pm: |
Bass boost control can and will alter gain settings. So just cause the gain/level is set according to the HU's voltage, it dosen't mean you can ignore/abuse the bass boost. Use it wisely. A good HU will most likely start to distort around 85% volume setting. Cheaper units will start much sooner. I find on my JVC dvd player, it will distort around 85%-90%. |
Post Number: 33 Registered: Mar-05
| Posted on Monday, April 04, 2005 - 12:57 pm: |
i have a pioneer, i only go 3/4 volume with it, i never go higher, its 2.2volts. I set the gain like 1/4, 3/8 way plus if i go any higher than that it seems to distort, its just that its not powerful, it sounds weak, but if i go up any higher it rattles/distorts, but I'm all paranoid about it now that I might be hearing my car rattling instead of the sub or something, i dont know... |
