Thread: Will this hurt amp/speakers? |
Bronze Member Username: Calaway
Austin,
TX
Post Number: 27 Registered: May-04
| Posted on Friday, April 01, 2005 - 04:12 am: |
I have 2-8 inch Fosgate HE2 dual voice coil(400watt RMS) subs. If I get a 2 channel amp with 300watt RMS at 2 ohms, will this hurt anything? |
Gold Member Username: Subfanatic
Walton,
Ky
Post Number: 1847 Registered: Dec-04
| Posted on Friday, April 01, 2005 - 10:43 am: |
what ezxactly is the question? also, are the subs DVC 4 ohm, or 2 ohm |
Austin,
TX
Post Number: 28 Registered: May-04
| Posted on Friday, April 01, 2005 - 10:48 am: |
they are dual 4 ohm. The question is if I under power them by 100 RMS will it hurt anything. |
Silver Member Username: Solacedagony
New Jersey
US
Post Number: 335 Registered: Oct-04
| Posted on Friday, April 01, 2005 - 11:11 am: |
As long as the amp doesn't clip the subs won't get hurt. |
Walton,
Ky
Post Number: 1849 Registered: Dec-04
| Posted on Friday, April 01, 2005 - 11:17 am: |
no it wont hurt as long as it didnt cluip as jake said |
Austin,
TX
Post Number: 29 Registered: May-04
| Posted on Friday, April 01, 2005 - 02:17 pm: |
How do I avoid clipping, by getting a good amp? Looking at RF amps.
Silver Member Username: Theelfkeeper
Stockbridge,
GA
Post Number: 166 Registered: Feb-05
| Posted on Friday, April 01, 2005 - 04:35 pm: |
a good amp can still clip, you just gotta make sure the gains are set right and not maxed and the wireing is of good quality, the right size for your application and connected properly. and that your charging system is suffecient |
New member Username: C_freh
Post Number: 1 Registered: Apr-05
| Posted on Friday, April 01, 2005 - 04:51 pm: |
I have a question, firstly let me start off my saying, i recently bought 2 brand new amplifiers and 4 new subwoofers. the Brand is CUSPID, i never heared of it before, but for the price i thought i would give it a try. Are these CUSPID things any good? please leave me some first or second hand accounts you had with this equipment. PS- the amplifier is a 4-channel but is 2x80wt RMS, does that make any sense? |
Post Number: 2 Registered: Apr-05
| Posted on Friday, April 01, 2005 - 04:55 pm: |
ohh yea its me chrissy again, the amplifiers are 1600 watts max power extreme 4 channel's and the subwoofers are 12" 600 watts max power |
Silver Member Username: Byrumjr
Post Number: 165 Registered: Jan-05
| Posted on Friday, April 01, 2005 - 11:56 pm: |
Chrissy Max watts are for 1/10 of a second RMS watts are what you go by when looking for amps and subs. Do you have the RMS watts at 4ohms and 2 ohms for the amps. Are the subs single or dual voice coils and what ohms are they? |
Post Number: 3 Registered: Apr-05
| Posted on Saturday, April 02, 2005 - 12:36 pm: |
I do not have the RMS for both, but i know they are single voice coil. I think i have the answer i need, this stuff is supposed to be crap from what people are telling me |
Bronze Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 83 Registered: Mar-05
| Posted on Sunday, April 03, 2005 - 06:51 am: |
Yes, it is. Rule of thumb, you get what you pay for. |
