Home > Message Board > Car Audio > Amplifiers > Archive through April 01, 2005 > Same gauge all around
Author Thread: Same gauge all around
KDE
Ok from my sub box connecting to my subs is 12 gauge wire, from my amp to the subs is 14 guage, is it better to have 12 all around?
Username: Invain
Michigan
United States
Post Number: 1854
It shouldn't matter too much, unless the wire from the amp to the subs is really long for some reason.
KDE
What about, if I the speaker wire fomr the sub box to the sub is 12 gauge, and from the amp to the subs is 18 guage, then it would be alot differnet. So it is better to have the same guage all around.
Username: Solacedagony
New Jersey
US
Post Number: 336
Unless you're sending like 3000W+ to your subs, I don't think it'll matter much. 18 gauge wire should be fine.
KDE
Yeah so its ok, but it would be better to be 12 gauge all around instead.
Home > Message Board > Car Audio > Amplifiers > Archive through April 01, 2005 > Same gauge all around [ « Previous ] [ Next » ]
