Thread: I NEED SOME HELP HERE |
New member Username: Jerrid0505
Post Number: 1 Registered: Mar-05
| Posted on Thursday, March 31, 2005 - 03:13 am: |
I JUST BOUGHT A KENWOO 600WATT KAC-7285 AMP TO GO WITH MY 2 10'S PIONEER SPEAKERS AND I WAS WONDERING IF THIS IS GOOD FIT FOR THEM CAUSE I REALLY DO NOT NO NOTHIN BOUT SOME BEAT AND I GOT THE AMP FOR ONLY $60 HOLLA BACK |
Bronze Member Username: Bnd_rulez
Phoenix,
AZ
Post Number: 52 Registered: Mar-05
| Posted on Thursday, March 31, 2005 - 04:51 am: |
It all depends on your subs. What is the rms wattage? MOst likely you're going to want to bridge two channels to each subwoofer. I had a 500 watt KAC with 2 crappy Audiobahns 12" and it sounded okay. |
Post Number: 2 Registered: Mar-05
| Posted on Thursday, March 31, 2005 - 12:16 pm: |
i have two pioneer 400 watt 10's so i dont about that, does that sound good holla back |
Bronze Member Username: Perrydog
Flint,
Michigan
Post Number: 92 Registered: Jan-05
| Posted on Friday, April 01, 2005 - 12:06 am: |
i had a pioneer 10 that rms'ed like at 150-175 i forget the 400 might be max |
