Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Kicker audio system?
Author Thread: Kicker audio system?
J3
ok so i wanna buy 2 kicker 12 inch l7s. i need to figure out a quality amp that would make these subs hit hard and is a pretty good price. also, would a ported box or a sealed box be better for this set up? any help would be appreciated.
Username: Addicted2bass
Miami, FLORIDA
Post Number: 458
A ported box would be good for L7's. A mtx audio 1501d should work fine also look into some ppi amps also. There good. Preferrably most of their older amps are better quality
Username: Davids2004
Houston, TX
Post Number: 764
How much are you looking to spend on the amp and defintely ported for alot of bass.
vcvvvcccvv
KICKER SUCKS!
Home > Message Board > Car Audio > Amplifiers > Archive through April 07, 2005 > Kicker audio system? [ « Previous ] [ Next » ]
