Thread: Punch 40 |
| Posted on Wednesday, March 30, 2005 - 11:24 am: |
How do you bridge a Punch 40 amp to a 15" punch woofer? |
Bronze Member Username: Joe_c
Oakwood,
Ga
Post Number: 90 Registered: Mar-05
| Posted on Wednesday, March 30, 2005 - 01:07 pm: |
how do you hook up a surround sound system??? j/k need a little more info is the sub dvc(dual voice coil) if so or not what ohm res. is the speaker and is it the old punch 40? |
| Posted on Wednesday, March 30, 2005 - 02:08 pm: |
its a single voice coil 4 ohm 15" woofer. |
Gold Member Username: James1115
Wilton,
Ct
Post Number: 2077 Registered: Dec-04
| Posted on Wednesday, March 30, 2005 - 06:08 pm: |
is it the old punch 40 like Joseph said? If it is they did not come with built in x-over's so I hope you were planning on using one. As for monoing that amp go left neg to right pos. That is a vey nice amp if it is the old one |
