Thread: What type of capacitor? |
Bronze Member Username: Perrydog
Flint,
Michigan
Post Number: 84 Registered: Jan-05
| Posted on Wednesday, March 30, 2005 - 03:46 am: |
i am looking into buyin a capacitor(s) i am gonna be runnin 2 kenwood 800watt amps what type of capacitor do u recremend and what farad or frade i forgot how to spell |
Bronze Member Username: Bassfreak596
Post Number: 96 Registered: Oct-04
| Posted on Wednesday, March 30, 2005 - 05:06 am: |
dont go for a capacitor.. go for an Alternator upgrade. upgrade th magic 3 wires n the Alt.. that is it ! if u still want to go for a capacitor, remember its approx 1 Farad for 1000w
Bronze Member Username: Importrapist
Savannah,
GA
U.S.A
Post Number: 88 Registered: Mar-05
| Posted on Wednesday, March 30, 2005 - 09:02 am: |
I have to agree with morphine, change that alt, but if you want a cap...like morp said its 1 fard per 1000watts, and i would go with Stinger caps... $hit i have one just for looks. I upgraded my alt and a yellowtop. |
Gold Member Username: Carguy
Post Number: 2132 Registered: Nov-04
| Posted on Wednesday, March 30, 2005 - 10:10 am: |
A capacitor will help only after an alternator upgrade. If however, you use self control with the volume level, then capacitor will help smooth out some voltage rails.
| Posted on Wednesday, March 30, 2005 - 11:10 am: |
HOW DO YOU BRIDGE A PUNCH 40 AMP TO ONE 4 OHM PUNCH 15" WOOFER? |
