Home > Message Board > Car Audio > Amplifiers > Archive through April 01, 2005 > Amp q
Author Thread: Amp q
Username: Perrydog
Flint, Michigan
Post Number: 83
when an amp says that it is like 2 ohm stable does that mean each channel is 2 ohm stable, i have an amp that says 2 ohm stable and 4 ohm brigeable
Username: Carguy
Post Number: 2135
What that means is, it is 2ohms stable in stereo mode and 4ohms stable in bridged mode. This is normal for most amps.
Username: Perrydog
Flint, Michigan
Post Number: 87
ok well would it be better for my amp to be in stereo mode or in bridged mode and does stereo mode mean that it wants 2 ohm per channel of 1 ohm per channel to = a 2 ohm load total(channels combined)
Username: Perrydog
Flint, Michigan
Post Number: 88
Username: Byrumjr
Post Number: 160
Most amps run as low as 2 ohms on each channel. When you bridge an amp both channels are running together at 4 ohms. If you bridge at 2 ohms each channel is running at 1 ohms.Not good can burn the amp up. Stereo mode or bridged mode, I think most run speakers in stereo and subs in mono or bridged.
Username: Perrydog
Flint, Michigan
Post Number: 89
so 2 ohm stable means 2 ohm per channel-------of course 4 ohm bridged means 4 ohm bridged lol
Username: Tragedy
San Jose, CA
Post Number: 167
yes adam.
Username: Tragedy
San Jose, CA
Post Number: 168
"so 2 ohm stable means 2 ohm per channel"
when it says 2ohm stable stereo...
Home > Message Board > Car Audio > Amplifiers > Archive through April 01, 2005 > Amp q [ « Previous ] [ Next » ]
