Home > Message Board > Car Audio > Head Units > Archive through April 13, 2005 > Infinity cd player
Author Thread: Infinity cd player
Username: Budman
I recently replaced the power antenna on my 2000 montero sport with the Infinity sound system I unhooked the battery now every time I start the vehicle the radio says CODE if I enter the code it works until I shut the ignition off then I have to reset the code PLEASE HELP
Username: Illuminator
Post Number: 7
You're going to have to take this to a dealership, it's inevitable.
JKW
The only time you should have to enter the code for the radio is when you disconnect the battery. If all the wiring to the radio is factory, then you might have a weak battery.
JKW
Home > Message Board > Car Audio > Head Units > Archive through April 13, 2005 > Infinity cd player [ « Previous ] [ Next » ]
