Home > Message Board > Car Audio > Amplifiers > Archive through April 01, 2005 > Kicker KX 600.1 AMP
Author Thread: Kicker KX 600.1 AMP
Username: Sqeeks80
Will this amp push 1 12" L7 4ohm,750 rms(old version)?What would be the best amp to drive this woofer to its max?
Username: Byrumjr
Post Number: 155
That amp does 300 rms at 4 ohms with 14.4 v and 600 at 2 ohms. Some birth certificate says it does 700 rms watts @ 2 ohms.
Username: Sqeeks80
So which Kicker ramp will i need to drive this woofer,i would to keep everything to Kicker...
but i am open to suggestion?
Username: Deadman
Kirksville, MO
Post Number: 28
That amp is a great one! I've heard it on the same sub you are talking about. I've also heard that same sub on some other amps...mtx, hifonics, jbl and rockford. The Kicker 600.1 was the cleanest and loudest of the five. You won't be dissapointed.
World
Username: Sqeeks80
What about the Kicker KX 850.2,i have been told that the KX 600.1 does not have enough power
to push the sub to its,reason being...it is 600 watt @ 2ohm stable,the sub is 4ohm and is 750rms.
It can be connected to be 2ohm but still 600 watt rms aint enough power,to my understanding
the out of your amp rms should equal your sub rms!My other option is the Alpine MRD 1001
which is 1000watt rms at 2ohm stable,is that a good choice or not?
Home > Message Board > Car Audio > Amplifiers > Archive through April 01, 2005 > Kicker KX 600.1 AMP [ « Previous ] [ Next » ]
