Home > Message Board > Car Audio > Amplifiers > Archive through April 01, 2005 > I need help finding an Amp
Author Thread: I need help finding an Amp
Username: Goon
Post Number: 50
I have two Infinity Kappa Perfects 12.1d. the rms on them is 350w, and the peak is 1400. im trying to keep the amp under 200$, but I don't wnast to sacrifice to much quality. I was thinking abotu the infinity ref. 1210a...what do you all think? thanks for the help.
Username: Carguy
Post Number: 2094
Try looking at PPI PC/PCX series amp on eBay. They're much better than Infinity/Alpine amps.
Username: Goon
Post Number: 51
Yeah I have heard they are good amps. problem is im not finding anything for under 200....i'm on a tight budget. any other suggestions?
goon
Username: Adampit
Post Number: 40
i have for sale a PPI PCX2125
Username: Goon
Post Number: 52
I would rather buy it new...thanks though. how much "worse" are the infinity amps compared to the ppi?
Username: Fishy
Tamarac Ft.Laud, FL
Post Number: 777
If you don't mind used off of E-bay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5763769299 %26
You'd have to run it at 1 ohm w/ those subs to get 600 watts however.
This wouldn't be a bad choice either:
http://www.acaraudio.com/product_info.php?manufacturers_id=26&products_id=453
Its not as "beefy" as the JBL and I believe would require 14 volts to provide 500 watts at 4 ohms bridged, but since its a discontinued item it can be had at a decent price and is "new".
There's tons of other choices out there. Thats just a couple I'm more familiar with.
-Fishy
Home > Message Board > Car Audio > Amplifiers > Archive through April 01, 2005 > I need help finding an Amp [ « Previous ] [ Next » ]
