Thread: One of my systems Complete! Just putting the finishing touches...check out |
Silver Member Username: Suleman36
Post Number: 410 Registered: Feb-05
| Posted on Saturday, March 26, 2005 - 04:39 pm: |
Ive decided to stay with the 10W7 H.O. wedge box and run it off the 500/1. For my componants in the front i went with the image dynamics cxs62 and im gonna power them with the ppi art 300.2 and use a batcap in place of caps. IM using the eclipse cd8454 for the HU. Am i missing anything else? What gauge power wire do i wanna run if its going in a sedan? What do i wanna set my HU crossovers too? jonathan help me out since you have that eclipse. Help me tune this thing..thanks p.s. How does knukonceptz sound for rca's??? |
Gold Member Username: Subfanatic
Walton,
Ky
Post Number: 1617 Registered: Dec-04
| Posted on Saturday, March 26, 2005 - 04:43 pm: |
those RCA's will work great, but i would run 4 gauge wireing |
Post Number: 414 Registered: Feb-05
| Posted on Saturday, March 26, 2005 - 06:04 pm: |
Speaking of the RCA's. For my system will i need 2 sets of 2 channel running from each amp to the HU. Thanks I think 4 meters will be plenty. |
Post Number: 415 Registered: Feb-05
| Posted on Saturday, March 26, 2005 - 10:17 pm: |
Post Number: 416 Registered: Feb-05
| Posted on Sunday, March 27, 2005 - 01:36 am: |
jonathan let me know |
Gold Member Username: Jonathan_f
GA
Post Number: 3556 Registered: May-04
| Posted on Sunday, March 27, 2005 - 01:50 am: |
4 guage kit will do the trick for the amps, remember that you'll need a distribution block for both those amps. As far as the crossover setting, it depends on whether you're doing easy or pro mode. Easy mode you don't as many choices of crossover slope, but either way begin with around 80hz for both drivers. If it sounds like too much bass in that region, move the HPF for the components up to 100 or 125hz. That should give you a start. Not too hard, just have to play around with it to get the sound you want. |
Post Number: 417 Registered: Feb-05
| Posted on Sunday, March 27, 2005 - 01:57 am: |
How do i wanna use the Batcap along with the Distribution block and which and how many distribution blocks should i get from knukonceptz.com and do i need 2 sets of 2 channel rca's? |
Post Number: 419 Registered: Feb-05
| Posted on Sunday, March 27, 2005 - 03:29 pm: |
Silver Member Username: Sony224422
Deep River,
CT
US
Post Number: 118 Registered: Dec-04
| Posted on Sunday, March 27, 2005 - 10:07 pm: |
yeah you'll need two sets of RCA's.. since your going hook two together right? I think im going to end up doing the same thing with my two amps, i hope it works haha. And if your only running two amps you only need one dis. block with atleast two out puts, probably should get one with like 3 or 4 incase you want to add more amps to your system. |
Post Number: 421 Registered: Feb-05
| Posted on Sunday, March 27, 2005 - 11:31 pm: |
Thanks eric |
Post Number: 422 Registered: Feb-05
| Posted on Monday, March 28, 2005 - 04:02 pm: |
which one of these distribution blocks do i wanna go with. Is it the 4awg going into 2 8 awg or??? http://www.knukonceptz.com/productMaster.cfm?Category=Distribution%20/%20Fuse%20 Blocks# |
