Thread: What amp to use and why. |
| Posted on Friday, March 25, 2005 - 02:07 am: |
ok im new at the car stereo thing and i really want 2 of the new kicker 12 inch L7s. these are 750 watt rms and 1500 watt max each. although they are 4 ohm. what amp do any of you think would sufficiently powere these bad boys? or better yet, what amp specifications would work best? any examples and/or help would greatly be appreciated |
Bronze Member Username: Abew330
Camarillo,
Ca
Usa
Post Number: 17 Registered: Mar-05
| Posted on Friday, March 25, 2005 - 03:07 am: |
sealed enclosure, 4ga. anl fuses get a 3farad cap, amp: mtx, fosgate etc.. my friend has a 988watt power acoustik amp.. pushes really good.. but i still think my mtx15's hit better and my punch 60ix |
| Posted on Wednesday, March 30, 2005 - 03:31 pm: |
would the sealed enclosure sound better or ported? and would a kicker kx1200.1 be good for these two subs? |
Gold Member Username: Carguy
Post Number: 2143 Registered: Nov-04
| Posted on Wednesday, March 30, 2005 - 05:52 pm: |
That amp will do well for your configuration. Sealed box is better for sound quality, ported is better at SPL.
Silver Member Username: Rob_brown
Post Number: 209 Registered: Jul-04
| Posted on Wednesday, March 30, 2005 - 10:25 pm: |
Ideally you would want an amp that could put out 1500 watts at 1 ohm, if you weren't afraid to try it, could be risky. I would say hifonics, but there have been some issues with that, so look for a good amp that puts out about 1500 watts. the kicker would be a good amp for a ported enclosure cause they are underrated and it takes less power, the bigger the box. |
Gold Member Username: Subfanatic
Walton,
Ky
Post Number: 1804 Registered: Dec-04
| Posted on Thursday, March 31, 2005 - 12:09 am: |
id say the hifonics brutus 1500d for cheap purposes, also, why in the hell would he get a 3 farad cap |
Post Number: 213 Registered: Jul-04
| Posted on Thursday, March 31, 2005 - 02:31 am: |
isn't it like 1 farad per 1000 watts roughly? definately not 3 farad. |
Silver Member Username: Tragedy
San Jose,
CA
Post Number: 166 Registered: Feb-05
| Posted on Thursday, March 31, 2005 - 06:27 am: |
well if hes looking to push 1500rms at 1ohm a cap aint going to help if his electrical system can keep up with the current draw. |
Silver Member Username: Johnnylemoine
LaPlace,
Louisiana
United States
Post Number: 476 Registered: Aug-04
| Posted on Thursday, March 31, 2005 - 02:16 pm: |
exactly, HO alt before a cap. i would say a 1200.1 kicker would be fine. it actually puts out about 1400rms. i would go with a ported box,at least thats what we did for my friends 2 L7 15's. LOW LOW BASS! |
| Posted on Friday, April 01, 2005 - 01:42 am: |
what amp does your friend use on those two l7 15's? |
