Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > SUGGESTION FOR THE BEST SUBS!!
Author Thread: SUGGESTION FOR THE BEST SUBS!!
Username: Cooter_lips101
Slidell, Louisiana
US
Post Number: 18
Hey i got 2 Eclipse Titanium Sw9122 and i need to know wuts the best amp or amps to use for these. Power Handling 1500W (Peak), 750W (RMS)
Impedance 4 ohm
Peak Power Handling 1500 Watt
Username: Abew330
Camarillo, Ca
Usa
Post Number: 15
look at mtx. fosgate.. mono, or 2ch.. get 900watt amp
Slidell, Louisiana
US
Post Number: 19
I heard a lot about the PPI, US, and Orion Amps being pretty good.
Username: Subfanatic
Walton, Ky
Post Number: 1491
i would look into US amps and orion amps for sure, but there are tons of great brands out there, if you wanted you could get two amps if you have the money, for instance get two ednine.1 and run them at 2 ohms for a 900 watt rms load to each sub
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > SUGGESTION FOR THE BEST SUBS!! [ « Previous ] [ Next » ]
