Thread: 1 ch amp 2 dvc Subs |
| Posted on Sunday, February 22, 2004 - 05:44 pm: |
Exactly how do I wire a 1 ch mono amp to 2 4 ohm dvc subs my amp is ohm stable. I wanna get the most power and not blow them up. Please Help  98.4 K | subs.bmp "" | | |
New member Username: Glasswolf
Post Number: 2 Registered: 02-2004
| Posted on Sunday, February 22, 2004 - 05:47 pm: |
wire them in parallel, straight to the amp. that's a 2 Ohm load and the best you'll do with those two subs
| Posted on Sunday, February 22, 2004 - 06:13 pm: |
so just 4 positives toghether annd 4 negative straight to amp? |
Post Number: 6 Registered: 02-2004
| Posted on Sunday, February 22, 2004 - 08:47 pm: |
you said the amp is 1 ohm stable right? mono amp? you want to bridge teh coils of the subs in parallel, then wire each sub to the amp.
New member Username: Stickstir2000
Post Number: 1 Registered: 02-2004
| Posted on Sunday, February 22, 2004 - 08:50 pm: |
yea it's 1 ohm stable. so i just connect the 2 positive and negatives onn each sub then hook it to the amp right? |
Post Number: 7 Registered: 02-2004
| Posted on Sunday, February 22, 2004 - 08:56 pm: |
both subs like so:
| Posted on Sunday, February 22, 2004 - 10:07 pm: |
thanks alot i really aprreciate it. |
