Thread: Woo woo |
Unregistered guest |
| Posted on Thursday, March 24, 2005 - 01:59 am: |
i was looking at zapco and they are very expensive. are they good for the price. or i could find something else for the two subs i got ATW12X they are rated for 3000 max and 2000rms each. what size of amp do i need .1000w.etc. very lost at this .( $1500.00 is a bit much for one amp , i am not in any comp.just want something very loud whith out bracking the bank.) help pls. |
Bronze Member Username: Nitescort
Post Number: 24 Registered: Mar-05
| Posted on Thursday, March 24, 2005 - 06:08 am: |
you buy a average sub and then want to power it with a great amp? get a Audiobahn to power it. might as well have junk powering junk. sorry for sounding so harsh but I just hate Audioblah. |
Silver Member Username: Rob315
Cuse,
NY
U.S.
Post Number: 388 Registered: Jan-05
| Posted on Thursday, March 24, 2005 - 06:36 am: |
audiobahn isnt junk...pursae...they arent the greatest by far...but they do get loud...they dont sound to great though...and i wouldnt power that audiobahn with that zapco amp unless you were going to be upgrading your sub in the future. |
THEGAME22193 Unregistered guest |
| Posted on Thursday, March 24, 2005 - 09:06 am: |
no problems i can returned them . give me some thing good .what about orion H212.4SPLHCCA 2000rms,2500max are they also crap if it is give something good with the same wattage. thanks for the responce. verry helpfull audiobahn going back. |
Gold Member Username: Carguy
Post Number: 2068 Registered: Nov-04
| Posted on Thursday, March 24, 2005 - 10:00 am: |
Audiobahn is not as bad as some people make them out to be. I've personally tested them. They are good for people with low budget. Unlike Sony/Pyramid/Lanzar/Pyle, it delivers. For better subs, look at RE X.X.X., JL, and Orion. If you have the space, then try 15".
New member Username: Thegame22193
Post Number: 3 Registered: Mar-05
| Posted on Thursday, March 24, 2005 - 10:13 am: |
thank for the info. 12 is what i want . like to have a tighter bass . don't care to much for 15's any model on the 12 i can use with 2000w rms the orion H2 sounds good. any thing better . i will say about $1300.00 for two subs. i am aready spending alot on two zapco amps so money is abit limited for the subs. zapco C2K-9.OXD and C2K-2.5X. |
Post Number: 2071 Registered: Nov-04
| Posted on Thursday, March 24, 2005 - 10:18 am: |
With the Zapco's C2K series amp, C2K 6 and 9 are the only 2 worth purchasing. Take a look at JL's 12" subs too. |
Post Number: 4 Registered: Mar-05
| Posted on Thursday, March 24, 2005 - 10:32 am: |
any particular model i need to look for . sorry for all the rookie question but i want this to be almost perfect. |
Post Number: 2072 Registered: Nov-04
| Posted on Thursday, March 24, 2005 - 11:08 am: |
Try JL Audio 10W7-3, JL 12W7 12". |
Silver Member Username: Fishy
Tamarac Ft.Laud,
FL
Post Number: 748 Registered: Sep-04
| Posted on Thursday, March 24, 2005 - 01:34 pm: |
I'm not sure that C2K-9 matches well with any 3 ohm subs. Its got some pretty strange power specs. It'd either produce 2000 watts into one w7 bridged or 2x400 into a pair. To get a more acceptable level of power you'd probably have to bridge the thing into a couple of series wired w7's which according to JL is something that should "be avoided at all costs". from here: http://www.jlaudio.com/tutorials/wiring/index.html I guess 2 10w7's at 400 watts each or one 13w7 at 2000 watts might not be too shabby, but I think if your going JL w7's your better off with a JL amp(1000/1).
-Fishy |
Post Number: 5 Registered: Mar-05
| Posted on Thursday, March 24, 2005 - 07:07 pm: |
hey guys what you think of this set up ... the zapco C2K-9.OXD and two orion H2. 2000 rms each. |
Post Number: 6 Registered: Mar-05
| Posted on Thursday, March 24, 2005 - 07:09 pm: |
hey guys what you think of this set up ... the zapco C2K-9.OXD and two orion H2. 2000 rms each. or i am still far from getting the subs right. |
Post Number: 2082 Registered: Nov-04
| Posted on Thursday, March 24, 2005 - 07:18 pm: |
Zapco's C2K 9 is 2200w rms of power. Are you sure you will be able to stand that much sound pressure? You will either go deaf or the car will break down. Anyhow, you will be very impressed with those combo. |
Post Number: 8 Registered: Mar-05
| Posted on Thursday, March 24, 2005 - 07:23 pm: |
THANKS MAN . that was the answer i was looking for . so i am going in the right direction ... perfect. |
