Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > SOME HELP PLS
Author Thread: SOME HELP PLS
new at this forum . great stuff . my question is
i got 2 atw12x audiobahn subs, they said rated 3000 full pow. and 2000 rms each, made custom box ported 38htz
need a amp the can move this thigs with good power something mono D 2ohm stable.any recomendations . thanks.....
Username: Thegame22193
THEY told me already this subs are crap so they are going back. going to get the zapco C2K9OXD.P
so i need 2 subs that can handle that amp .
and i any sugestions on a enclosuse for them it will be appriciated .
want the competition sound but with out going to competitions.
Username: Carguy
Post Number: 2067
Zapco C2K 9 is a great amp. Take a look at RE X.X.X., JL for powerful sounding subs. On eBay, you will find a company that makes custom boxes.
Post Number: 7
what about this set up .
C2K-9.OXD and two orion H2. is this goog or i a'm still far from getting the subs right
Username: Carguy
Post Number: 2083
You might want to get the amp first and give it a try. Sound is very subjective, so if it sounds good to you, then that's all that matters.
Post Number: 9
what do you mean by subjective. explain.
Username: Carguy
Post Number: 2084
Someone might say such and such sucks cause maybe it didn't meet their requirement. The problem is different people have different needs/standards. So you can't judge something based on opinions. It's always best to try it for yourself. Make those audio shops earn their money.
Post Number: 12
tanks for the explanation.so i will go with that set up and hope for the best .
Username: Andy1984
Saint Louis, Missouri
Hello everyone. I just joined this message board, and I have a question about power wires. I bought an amp kit from wal-mart, by scosche, and the power wire came with a fuse holder already installed in the line. My dillema is that the ring that is on it doesn't fit around my battery post. Is it supposed to fit around it, or just sit on it? The kit didn't come with a power terminal so I bought one. The power terminal has to holes on the back for 8 gauge wires, but my power wire has a ring shaped battery terminal on the end of it. Should I uncrimp the terminal and connect it to the power terminal? whats going on?
Username: Subfanatic
Walton, Ky
Post Number: 1592
that really confused me dude lol
Username: Rzarector
Coquitlam, Bc
Post Number: 260
ring goes around the bolt that crimps the terminal then
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > SOME HELP PLS [ « Previous ] [ Next » ]
