Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > 4 gauge vs 8 gauge
Author Thread: 4 gauge vs 8 gauge
I am going to be running another amp to my system. I have 4 gauge already run but if i use a distribution block then it splits into two 8 gauge wires. If the wire is going to be short will 8 gauge still rob my amp (hifonics bx1500d) of power?
Username: Theelfkeeper
Stockbridge, GA
Post Number: 124
it depends on the length. you can pull up to 65 amps for 4-7 feet on a 8 gauge wire. i assume your 4 gauge is around 16 to 19 feet, if so you can pull up to 65 amps on the 4 gauge. (from MECP Basic Installer Book)
its always best to have a larger gauge then needed for increased power flow and future upgrades.
voruganti
visit this link , this says how to pick right gauge
http://www.crutchfield.com/installguide/S-HbwZ4DWfqq8/cable_gauge.html
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > 4 gauge vs 8 gauge [ « Previous ] [ Next » ]
