Thread: Would a capacitor fix my problem |
New member Username: Volfenhag1200
Post Number: 3 Registered: Mar-05
| Posted on Wednesday, March 23, 2005 - 04:28 pm: |
My amp does fine until I turn my bass up then it blows my fuse. I think I am gettin a power overload. If I got a capacitor and hooked it up would it fix this problem? |
| Posted on Wednesday, March 23, 2005 - 05:15 pm: |
no.....the only thing that will fix your problem is to get a bigger fuse, but be careful because when you get a bigger fuse you are allowing more current to travel thru your power cable....each gauge of cable can only safely handle a certain amount of current safely so if you just throw in a bigger fuse, the fuse wont blow anymore but you may melt your cable. You might have to also upgrade your power cable to a bigger gauge..... |
Gold Member Username: Carguy
Post Number: 2058 Registered: Nov-04
| Posted on Wednesday, March 23, 2005 - 06:02 pm: |
What is the amp's internal fuse size? What brand/model is it? Do your lights dim with heavy bass? |
Post Number: 4 Registered: Mar-05
| Posted on Wednesday, March 23, 2005 - 09:52 pm: |
It has two 40 amp fuses on the amp. Its a Volfenhag 2000 watt amp. And yes my lights dim when I play heavy bass. Do you know what the problem is? |
Silver Member Username: Kojak28
Augusta,
GA
Post Number: 118 Registered: Feb-05
| Posted on Wednesday, March 23, 2005 - 10:03 pm: |
Power hungry amp. Feed it. "More juice, please!" What class amp is that(x,d,a/b)? |
Post Number: 5 Registered: Mar-05
| Posted on Wednesday, March 23, 2005 - 10:05 pm: |
What do you mean by a class amp? |
Post Number: 2061 Registered: Nov-04
| Posted on Wednesday, March 23, 2005 - 10:38 pm: |
Bradley, you'll need at least 80A fuse near the battery. Do not go over that amount. Unless you have HO alternator, chances are your stock is only 65A - 75A max. Therefore if your amp is trying to draw more than allowed, it'll try and get the power from the battery. If that gets drained (battery is dead), then your alternator is next. That is not all, your internal electronic system will either shut down or get damaged. Not really worth it. The repair cost will be 5x - 10x the cost of HO Alternator. So save up your money and invest in HO Alternator. Don't ignore dimming lights. It is a very serious warning. |
Post Number: 7 Registered: Mar-05
| Posted on Thursday, March 24, 2005 - 07:34 pm: |
Its Max Power Output-1000Wx2 2 Ohm- 300Wx2 4 Ohm- 200Wxs Bridged Power @ 4 ohm- 600Wx2 I have an 80 amp fuse at battery and 40ampx2 on the amp. I have the subs connected at 2 ohm and in parallel. |
