Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Bridge a mono amplifier???
Author Thread: Bridge a mono amplifier???
Username: Truckguy
Mission, Tx
Usa
ok.... so i went and bought some speakers (there ok) and they guy installed them and he said OH OH were going to have to bridge this amp?? ...buts its a mono amp?? so is that posible soposly this "profesional" said he did it? so what do u guys think?
nick_sq
depends on the amp...usually not because there is only 1 channel
Username: Carguy
Post Number: 2050
You can't bridge a mono amp. Maybe he meant connecting the subs in parallel or try and confused you.
Just like when you take your car in for repair. Some if not lot will try and tell you have problems here and there to make money. I was at Midas shop, and the service guy was telling the customer that he needed brake job, rotor replaced, new pads, transmission fluid replaced, brake fluid replaced blah blah blah. Then the customer told him that it was already done at the last visit. So he then recommended brake pads.
Now if they actually looked at the problem then there is no way that could've happened.
Really, how do you explain telling a customer that they needed a part replaced again? This is why I don't let anyone touch my car.
I am not sure if the mechanics are that stupid or just trying to make quick bucks off naive consumers.
Username: Miso
Slovakia
Post Number: 45
on some amps(higher end) you can bridge TWO monoblocks,so maybe he´s right,check manual.
Username: Truckguy
Mission, Tx
Usa
Post Number: 7
ok thanks ill try to chek it out to see what can i do about it
Username: Kojak28
Augusta, GA
Post Number: 119
Isaac, that dude at Midas-Chances are, he was a salesman. Salesmen "pitch" what & HOW he thinks he can sell. If the vehicle had a certain # of miles on it, then yes it would be time for some of those services. BUT- there is only ONE catch, you can tell when a salesman is lying to you: If his lips are moving.
Username: Carguy
Post Number: 2062
Yea but an honest mechanic is suppose to look the car over first before telling a consumer what's required fixing. Anytime you have someone guessing, is when people get ripped off. Brakes are perfect example. Let's say after 60,000 miles, it needs servicing. However, if most of that mileage came from highway driving, then it will last way past 60k. To have a perfectly working and non worn out brakes replaced is a crime. I see that happening often, especially to female drivers. I don't know how those guys sleep at night.
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > Bridge a mono amplifier??? [ « Previous ] [ Next » ]
