Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > WHICH AMP FOR Z6?
Author Thread: WHICH AMP FOR Z6?
Username: Ethan68
Post Number: 8
Can anyone please tell me which amp I should get to power 4 Boston Acoustics Z6 speakers, I want best SQ. Choices are:
JL Audio 300/4
Phoenix Gold XENON 100.4 or 200.4
PPI DCX600.4 or DCX1000.4
Alphasonik PMA4150A
Username: Jeremyc
OK in less t...
South Korea
Post Number: 573
I would do the JL 300/2 or if you really want good SQ 2 JL 300/2s biamped on them. Thats the same setup I am running on my Focals. Nice choice by the way. I had the older pros in my last stereo and loved them.
Username: Ethan68
Post Number: 9
Can anyone tell me which amp is better, the PPI DCX1000.4 or the PPI PCX-4125 or the JL300/4.
Thanks Jeremy for your suggestion, but I prefer a 4 channel amp.
Username: Jeremyc
OK in less t...
South Korea
Post Number: 587
??? Why a 4 chanel, when you only need a 2 chanel?
Username: Ethan68
Post Number: 10
I've got four Z6 speakers, 2 fronts and 2 rears
Username: Jeremyc
OK in less t...
South Korea
Post Number: 598
Yeah the only problem I see is that 75 watts RMS might not be enough to really push them. Why are you running 2 sets of them? What type of car?
Username: Nitescort
Post Number: 28
PCX just cause I think the new DCXs are fugley.
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > WHICH AMP FOR Z6? [ « Previous ] [ Next » ]
