Thread: Ed nine.1 |
Silver Member Username: Rob_brown
Post Number: 195 Registered: Jul-04
| Posted on Wednesday, March 23, 2005 - 12:16 am: |
If my amps input sensitivity is 1.5mv-7v and my headunit puts out 6.5, it's a pioneer premiere, so it really does, does that mean i should turn the gain almost all the way up or does thathave nothing to do with the gain? Thanks |
Silver Member Username: Jeremyc
OK in less t...
South Korea
Post Number: 570 Registered: Jun-04
| Posted on Wednesday, March 23, 2005 - 12:31 am: |
You match the gain with the out put on your amp. Since the Output is that high your gain should stay pretty low. Keep in mind when you turn up the gain, your turning up the (SENCITIVITY). So your making the amp work harder looking for the signal, and that leads to distortion. Thats not a perfect example of what happens, but its an easy way to understand the coralation between gain and line out voltage. |
Post Number: 198 Registered: Jul-04
| Posted on Wednesday, March 23, 2005 - 12:50 am: |
what's the output of my amp? i'm not really sure what that is, just that the variable input sensitivity is 150mv-7v |
Post Number: 199 Registered: Jul-04
| Posted on Wednesday, March 23, 2005 - 12:55 am: |
oh, my HU puts out 6.5 volts |
OK in less t...
South Korea
Post Number: 571 Registered: Jun-04
| Posted on Wednesday, March 23, 2005 - 12:56 am: |
The output on your amp doesn't change with the line out voltage on your deck, or the gain setting. Look on ED's web site and they will have the rms output of your amp listed. |
Post Number: 200 Registered: Jul-04
| Posted on Wednesday, March 23, 2005 - 01:02 am: |
oh, in watts? it puts out 1200 rms at 1 ohm, that's what i'm running it at. |
Post Number: 201 Registered: Jul-04
| Posted on Wednesday, March 23, 2005 - 01:03 am: |
it's powering a 15" X.X.X |
Post Number: 203 Registered: Jul-04
| Posted on Wednesday, March 23, 2005 - 01:11 pm: |
anyone? |
