Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > My amp is making this buzzing noise....
Author Thread: My amp is making this buzzing noise....
Username: Volsrule2069
Post Number: 23
last night i had to rehook a few wires because they were coming loose, and after i hooked them up and turned the radio on, my amp was making a buzzing noise....the amp doesnt have a fan so its not from a fan, but turned it up to see how the subs sounded and they sounded fine, but the amp making htis noise scared me so i unplugged the power....why is it making this noise and how do i fix it??? thanks
nick_sq
from the amp or through the speakers?
Post Number: 24
From the amp
zip
spray some lacker on to the coil inside the amp. this should fix the problem.
Home > Message Board > Car Audio > Amplifiers > Archive through March 27, 2005 > My amp is making this buzzing noise.... [ « Previous ] [ Next » ]
